Here is an AI-generated post about Nikon cameras being hacked with AI:
Nikon cameras are being hacked with AI: custom firmware adds new features and community mods
For over a decade, Nikon firmware hacking was largely limited to older EXPEED 2 and EXPEED 3 DSLRs, while newer mirrorless bodies remained locked behind proprietary encryption and signature validation—until now.
Over the past few weeks, a new wave of AI-assisted reverse engineering has erupted across Chinese social media and tech forums (Bilibili, Zhihu, Xiaohongshu, SMZDM), GitHub, and Reddit (
r/WonderLantern, r/Nikon, r/NikonZ8). Using Large Language Models alongside Ghidra and QEMU emulators, independent developers have cracked Nikon’s Z-mount encryption and started flashing functional custom features onto cameras including the Nikon Z8, Z7, Z6, Z5, Z30, Nikon 1 J5/V2, and classic DSLRs.How It Works & Important Warnings
Developers discovered that Nikon reused legacy XOR keystreams even on newer EXPEED 7 flagships like the Z8 and Z9. Using
nikon-fw-key-tool, builders can decrypt official firmware, patch ARM/Thumb assembly, and re-sign modified .bin files to pass checksum checks during a standard menu update—testing changes first inside open-source QEMU hardware emulators (z8-qemu, z9-qemu, z30-qemu, z5-qemu, z7-qemu, zf-qemu, zr-qemu).Use at your own risk: Almost all Z-series hacks are experimental, require you to compile your own official Nikon
.bin file, and carry real risks of bricking (a Z9 owner recently had to desolder a flash chip after a failed install). Firmware compatibility is also strict—for example, Nikon pulled Z8 C 3.11 after releasing C 3.12 on October 20, 2026, locking updated bodies out of current Z8 patches.Complete List of Currently Available Nikon Firmware Hacks
1. Nikon Z-Series Mirrorless Hacks
- Nikon Z8 (
XinmiaoZhao/NikonFirmwarePatchv0.4.0 — FW C 3.11 only): Unlocks 3:2 8.3K open-gate N-RAW (8256 × 5504 at 24p/25p/30p; no 50/60p or ProRes/H.265 open-gate), seven anamorphic desqueeze ratios (1.25×–2×), selectable ProRes HQ/422/LT/Proxy, five H.265 bitrate tiers, Sony S-Log3 and RED Log3G10 profiles, C15/C30 RAW pre-capture, and in-camera 4/8/16/32-frame pixel-shift merging toNEFX. (Reddit discussion) - Nikon Z30 (
WonderLantern/wonder-lantern-z30— FW C 1.20 only): Adds 12 modular extensions including higher video bitrates (up to ~200 Mbps max / 168 Mbps average target in 4K), 25-minute slow-motion recording (up from 3 min), 900-second Manual exposures, live histogram + electronic level, photo zebras, custom WAV shutter sounds, aspect-ratio crop masks, JPEG date stamps, 5 GHz Wi-Fi options, and uncompressed/lossless NEF choices. - Nikon Z5 (
WonderLantern/wonder-lantern-z5— FW C 1.50): Adds customizable live histogram + electronic level overlays, 3×3 and 2×2 grids, photo zebras, battery percentage readout, focal-length display for CPU lenses, WAV shutter sounds, a standby wake-up fix, and beta portrait UI rotation. - Original Nikon Z6 (
WonderLantern/WonderLantern-z6v1 &vic2349/Wonder-Lantern— FW C 3.80): Kickstarted by a viral Reddit demo of a Z6 “meowing” on every shutter press, this mod adds 15 custom WAV shutter sound slots, extended long exposures with top-LCD countdown, and custom framing guides (3:2,21:9,65:25XPan,4:3,2.35:1) with non-destructive crop metadata embedded in NEF files (recoverable in Lightroom). (Known bug: slows USB/PixelCake tethering.) - Original Nikon Z7 (
tylermcm/WonderLanternZ7— FW C 3.80 without paid RAW upgrade): Adds a persistent native 3×3 rule-of-thirds framing grid alongside Nikon’s stock 4×4 option. (Not for Z7 II; Reddit thread.)
2. USB Unlocks & Z6 III / Z9 / ZR Research
NikonUnlock(No Firmware Flash): Windows USB + SD cardKEYtool that enables paid ProRes RAW / Blackmagic RAW HDMI output and unlocks all 29 regional menu languages on original Z6/Z7 (C 3.80), with experimental simulation-only HDMI RAW support for Z6 II/Z7 II (C 1.70).- Z6 III, Z9, Z5 II & ZR Status: While WonderLantern researchers report completing Nikon ZR firmware decryption (meaning every known Nikon mirrorless line has now been decrypted at a research level) and early EXPEED 7 extension work is underway via
NLoader, no public reproducible custom firmware exists yet for the Z6 III, Z9, Z5 II, or ZR. (For the ZR, Nikon has officially announced firmware v2.00 with Log3G10 and 2027 open-gate/anamorphic support.)
3. Nikon 1 Mirrorless Hacks
- Nikon 1 J5 (
XCQi/Nikon-1-custom-firmwarev11.1 — FW C 1.01): Provides ready-to-flash.binfiles enabling Aperture-Priority metering, Auto ISO, and focus magnification with unchipped manual lenses, assignable Wi-Fi/Delete buttons, 1-second interval shooting, a 32-language JDM unlock, and expanded FT1 adapter compatibility (including the Nikon 200-500mm). (Reddit thread) - Nikon 1 V2 (
lcat2000/nikon1-zhtw-language-patch— JDM FW C 1.22): Unlocks all 29 international menu languages on Japanese-market V2 bodies.
4. Classic Nikon DSLRs & Non-Firmware Utilities
- Legacy DSLRs (
Nikon-Patch/nikon-firmware-tools): Supports the D300, D300S, D3100, D3200, D3300, D5100, D5200, D5300, D600, D610, D7000, D800, D800E, and D4 with 1080p video bitrates up to 54–64 Mbps, recording time-limit removal, clean HDMI (including newly merged October 2026 clean HDMI + audio for the D3200 C 1.04), astrophotography “Star Eater” hot-pixel filter removal, lossless NEF options, and third-party battery support. A separate new project,OpenEXPEED, is also actively reverse-engineering the Nikon D90 firmware. - Non-Firmware Utilities:
1dlut-z30-filters(writes custom 1D tone curves to Z30 Picture Control slots via USB),mtplvcap(USB Live View webcam relay for OBS),furble(ESP32 DIY Bluetooth shutter remote), andnikonpc.com(custom Picture Control editor).
Summary Table: Hackable Nikon Cameras
| Camera | Project | Base FW | Main Unlocked Features | Status |
| Nikon Z8 | NikonFirmwarePatch | C 3.11 | 8.3K 3:2 Open-Gate N-RAW, S-Log3, RED Log3G10, ProRes/H.265 bitrates, 1.25×–2× desqueeze, RAW pre-capture, NEFX pixel-shift merge | Experimental |
| Nikon Z30 | WonderLantern-z30 | C 1.20 | ~200 Mbps 4K target, 25-min slow-mo, 900s shutter, histogram + level, zebras, 5 GHz Wi-Fi, WAV shutter | Experimental |
| Nikon Z5 | WonderLantern-z5 | C 1.50 | Histogram + level, zebras, battery %, CPU focal length, 3×3/2×2 grids, wake-up fix, portrait UI (beta) | Experimental |
| Nikon Z6 | WonderLantern-z6 | C 3.80 | 21:9 / 65:25 / 2.35:1 guides with recoverable NEF crop, extended shutter countdown, 15 WAV shutter slots | Experimental |
| Nikon Z7 | WonderLanternZ7 | C 3.80 | Persistent 3×3 rule-of-thirds framing grid (non-RAW upgrade bodies only) | Experimental |
| Z6 / Z7 / Z6 II / Z7 II | NikonUnlock | C 3.80 / 1.70 | USB ProRes RAW / BRAW HDMI unlock & 29-language JDM menu unlock (no firmware flash) | Active / Sim |
| Z9 / ZR / Z6 III / Z5 II / Zf | WonderLantern / NLoader | Various | Key decryption (Z9/ZR), QEMU emulators, early card-loaded extension research | Research Only |
| Nikon 1 J5 / V2 | XCQi / lcat2000 | C 1.01 / 1.22 | Unchipped MF lens metering/Auto ISO, custom buttons, 1s interval, FT1 fixes (J5), 29/32-language unlock (J5/V2) | Active |
| D90, D300–D800E, D4 | Nikon-Patch / OpenEXPEED | Various | Up to 64 Mbps video, no time limits, clean HDMI (+audio on D3200), Star Eater removal, 3rd-party batteries | Mature / Research |
Additional community roundup: r/Nikon AI Hacking Thread.
This custom shutter sound mod makes the Nikon Z6 meow when you take a photo:
The post Nikon cameras are being hacked with AI: custom firmware adds new features and community mods appeared first on Nikon Rumors.
Related posts:
- Major Nikon Z9 firmware update version 5.30 and minor Nikon Z5II firmware update version 1.10 released
- Update: here is the full list of all discounted Nikon cameras and lenses in the US
- Introduction to Nikon NX Studio and flexible colors
Lese weiter....
