......ich war so frei, ein belangloses Bild aus meinem Archiv zu suchen, freihand, im Hochformat, focus liegt auf der Sonne der dritten "Vina Sol" Flasche von links, einer der "rechten" AF-Felder also kein Kreuzsensor.
Aufnahmefomat Raw, nur in ACR entwickelt.
Bitte keine künstlerische/inhaltliche Diskussion, Danke.
Exif:
Nikon D800
24.0-70.0 mm f/2.8
ƒ/4.5
62.0 mm
1/125
3600
Blitz (aus, nicht ausgelöst)
Make - NIKON CORPORATION
Orientation - Horizontal (normal)
X-Resolution - 240 dpi
Y-Resolution - 240 dpi
Software - Adobe Photoshop CS5.1 Macintosh
Date and Time (Modified) - 2015:11:09 17:33:02
Artist -
Copyright -
ISO Speed - 3600
Sensitivity Type - Recommended Exposure Index
Exif Version - 0221
Date and Time (Original) - 2014:07:08 13:47:36
Date and Time (Digitized) - 2014:07:08 13:47:36
Exposure Bias - 0 EV
Max Aperture Value - 2.8
Subject Distance - 1.26 m
Metering Mode - Multi-segment
Light Source - Unknown
Sub Sec Time - 00
Sub Sec Time Original - 00
Sub Sec Time Digitized - 00
Color Space - Uncalibrated
Focal Plane X-Resolution - 204.84021
Focal Plane Y-Resolution - 204.84021
Focal Plane Resolution Unit - mm
Sensing Method - One-chip color area
File Source - Digital Camera
Scene Type - Directly photographed
CFAPattern - [Red,Green][Green,Blue]
Custom Rendered - Normal
Exposure Mode - Auto
White Balance - Auto
Digital Zoom Ratio - 1
Focal Length (35mm format) - 62 mm
Scene Capture Type - Standard
Gain Control - High gain up
Contrast - Normal
Saturation - Normal
Sharpness - Normal
Subject Distance Range - Unknown
Lens Info - 24-70mm f/2.8
Lens Model - 24.0-70.0 mm f/2.8
Compression - JPEG (old-style)
Thumbnail Offset - 1106
Thumbnail Length - 4696
Coded Character Set - UTF8
Application Record Version - 0
By-line -
Date Created - 2014:07:08
Time Created - 13:47:36+00:00
Copyright Notice -
IPTCDigest - 3cd92763350004f1ea3db4e62c0d6fba
Displayed Units X - inches
Displayed Units Y - inches
Global Angle - 30
Global Altitude - 30
Photoshop Thumbnail - (Binary data 4696 bytes, use -b option to extract)
Photoshop Quality - 12
Photoshop Format - Optimised
Progressive Scans - 3 Scans
XMPToolkit - Adobe XMP Core 5.0-c061 64.140949, 2010/12/07-10:57:01
Format - image/jpeg
Creator -
Rights -
Creator Tool - Ver.1.10
Rating - 0
Metadata Date - 2015:11:09 17:33:02+01:00
Lens ID - 147
Image Number - 12314
Approximate Focus Distance - 1.26
Color Mode - RGB
ICCProfile Name - Adobe RGB (1998)
Document ID - xmp.did:0280117407206811822AC443F7D7139E
Original Document ID - 0B5A369B45BE960BE9B056D87D1307A0
Instance ID - xmp.iid:02801174072068118DBBC665D2CF594E
History Action - derived
History Parameters - converted from image/x-nikon-nef to image/tiff
History Instance ID - xmp.iid:0280117407206811822AC443F7D7139E
History When - 2015:11:09 17:32:41+01:00
History Software Agent - Adobe Photoshop Camera Raw 6.7.1 (Macintosh)
History Changed - /
Derived From Instance ID - xmp.iid:01801174072068118DBBC665D2CF594E
Derived From Document ID - xmp.did:0280117407206811822AC443F7D7139E
Derived From Original Document ID - 0B5A369B45BE960BE9B056D87D1307A0
DCTEncode Version - 100
APP14 Flags0 - [14]
APP14 Flags1 - (none)
Color Transform - YCbCr
Camera ID - 54532
Camera Type - Digital SLR
